Air Bag light flashing Red, any ideas?
DominickJ30
Car: 1993 Infiniti J30t
This is the story, 2 weeks ago my car started acting up, the trans pump was making noise whining. So I took it to a shop to get diagnosed. This big fat mofo drove my car and told me wasup. Then when I got in to leave I noticed the airbag light flashing from thsi point.
Just wondering if this guy with his weight and girth could have set somthing off or is it just a coincidence?
I dont really have easy access to an obd1 computer so if you guys have any ideas that would be great. Thanks
yodawill2000
Car: 94 Infiniti J30
Try to reset it ??Turn the ignition on and hit the door actuator really fast for about 7 to 10 depresses
nick9802
My airbag light is doing the same thing. Where exactly is this button i should hit?
acegunter
Car: 96 J30
Turn your ignition from off to on and then You need to press the door switch atleast 5 times in 7 seconds. SRS will be in the diagnistic mode. Let us know what the light does after that.
If you switch the ignition off the Airbag is reset.
Modified by acegunter at 2:42 PM 1/22/2007
DominickJ30
By dooor switch, do you mean teh lock unlock lever?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
No the thing on the B pillar...
zerothread/217462
DominickJ30
Great thanks Wes, Ill try it tommorow.
DominickJ30
It worked, thanks Wes.
