Air bag harness
Rsanchez9688
Car: 1997 Nissan 240sx
So I recently installed an after market steering wheel in my car. I'm trying to find out which wires are for the airbag and which wires are for the horn. My car is a 97 240sx. I have a blue,red,black,yellow and white wire. Thanks
centralcoaster33
Car: 1997 Nissan 240SX #5
Just give a pair of wires 12 volts until you either hear car horns or your airbags deploy! Okay, just kidding. Use the FSM wiring diagram. Look at the EL chapter, page 104. :bigthumb:
Here's a link to each chapter in the FSM:
http://www.nicoclub.com/FSM/240sx/1997/
Welcome to NICO Club!
PS - the wiring diagrams are schematic, so there's a key. Abbreviations for wire colors and how to read a wiring diagram are in the GI chapter, look to page 11 for the wire color codes.
ca18det_boy
Should be a green wire with a white stripe. If you check it with a multi meter it should have 12V, ground it out and your horn should go off. The black and white wires should be for the airbag light. Use a 2.7ohm resistor (I believe ) and wire them together to get your light out.
Rsanchez9688
Thank really appreciate it.
