Aimgain Suspension
TBrack
Car: none
I haven't found any previous threads about this but, I have found a suspension set up that Aimgain makes called a "Sedan Damper". Through the translations from dictionary.com/translator, I have discovered that it is a shock/spring combo that can be adjusted to accommodate any taste in hight and will allow your car to clear your wheels just by simple adjustments. It's a little expensive ($2500 to import +shipping to your house) but I do believe I am going to get me some instead of the typical tokio blues with cc springs.
http://www.aimgain.net/products/dumper_detail.html
Here is the Aimgain G50 with the suspension kit on.
midnightsliding
wow 2500 plus time waiting for it to come across from Jland. Fthat just make some for the Q.
q45VIP
Car: 94' Q45t
lasoyafan wrote:I haven't found any previous threads about this but, I have found a suspension set up that Aimgain makes called a "Sedan Damper". Through the translations from dictionary.com/translator, I have discovered that it is a shock/spring combo that can be adjusted to accommodate any taste in hight and will allow your car to clear your wheels just by simple adjustments. It's a little expensive ($2500 to import +shipping to your house) but I do believe I am going to get me some instead of the typical tokio blues with cc springs.
If I were to get new coils for the G50, I would go with the Insurance coils.One ton garage said the Y33 coilovers go for a bit more than $1400.00G50 coilovers are less expencive than the Y33 so, lets say you get them for $1400.00 you save $1k +
Check the thread where they review the Insurance suspension.
Hope this helps.
TBrack
Car: none
looked around and didnt find em. got a link or anything?`
antbo
JIC coilovers. the good part is that they have them in stock. in the US
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Just get a G50 active and import the height control unit. Same price... but, electronically controlled hydraulic system FTW.
q45VIP
Car: 94' Q45t
lasoyafan wrote:looked around and didnt find em. got a link or anything?`
Here's the link for the Insurance coils.http://www.insurance-group.net...n.htm
Also , check out Buddy clubs New SEDAN Coilovers.They make them for the G50 too.There is a PDF file at the bottom of the pages with specs.http://www.buddyclub.jp/s-w_damper/index.html
