180sx wrote:so the air aidle valve (ka24e back of throtle body) the air intake is done through intake pipe factory ... with turbo i don't want to weld bunges on my intercooler piping , can i just attach the mini k&n filter to it ???just like on valve cover? i don't have emission testing here
no it wont work. the IACV (Idle Air Control Valve) has to be plumbed into the cold/charge pipe. sorry
180sx wrote:also are only vaccum lines needed after egr aiv and buterflies and canister remowallis fuel pressure reg ? am i right (rest of ports can be used for bov ..hmm thats it ,rest pluged up i guess ?
that's pretty much what I'm running. I have my boost gauge running off of one source that I have t'd off to run to the actuator for the butterflies. then I ran a line exclusively to the FPR, the other line I ran to my BOV/Wastegate. I decided to use an ID signal from my intake to run my wastegate to compensate for the pressure drop in the intercooler. if I can get in my garage soon (need to get my dad's Tempo out of there) I'll take some pictures that I've been promising everyone.
180sx wrote:also what oil are you guys using ???? 20w50
I'm running Valvolene 10W30. runs just fine but then again I do have an oil cooler installed.
180sx wrote:i did find out my ka24e is 8.6 comp not 9.1 so i have air temp sensor what should i do just cut it or should i be making a bung for it
i just disconnected mine. I havent really had much trouble other than it running a bit rich when it's cold out (but i am my bov externally so I think that's more of the cause) if you can make a bung in your intake go for it otherwise it shouldn't cause you too much grief to remove it altogether.
180sx wrote:also i have a&f gage if i hook it up to stock o2 can i boost based on that reading untill i start leaning /? and how do i tell when maf maxes out ???i am curious how far stock parts go as far as fuel/air or the only way is acctual dyno?
PLEASE! PLEASE do not go based off of that to tune. our O2 sensor is a narrowband POS. i'm running 8.5psig on my 8.6:1cr SOHC right now w/ stock fuel system and Walbro 255lph. I dont really feel safer going higher than that. turbo is .48ar t3/t4 btw. if you're going to try and tune it either shell out the $ for a good wideband o2 sensor or take it to a dyno and use theirs. just turning the boost up until you 'lean out' is DEFINITELY not safe though. there are many other limiting factors that will cause your motor to blow up like a grenade if you exceed their tolerances. look at all the people who have just blown rods out of their blocks. they were running just fine afr wise. I dont plan on pushing my stock rods past what I am right now. I am confidant they can handle up to 300 rwhp (but that would really be pushing it) I do however have the liberty of owning a spare motor so I'll rebuild that for more power. no need to get greedy when it's going to land you cruising for chicks on your bicycle.
