iceman.chris »
https://forums.nicoclub.com/iceman-chris-u123192.html
Fri Apr 17, 2009 10:19 am
My timing chain was getting noisy, so today I replaced the tensioner with a new oem one. Once it was installed I cranked the engine a few times with the fuel pump disconnected, then connected it started it. The car ran alot quieter, but also about 250 rpms lower than normal idle, 400rpms lower than it should have been at (for cold idle).
I shut it off and tried to start it again and it won't start. I can crank away and nothing. Makes a funny noise every once and a while, can't really describe it other than like two balloons rubbing against each other .
But that might be unrelated, as it did it a bit before anyways. Could the timing have slipped?
