Here's some ideas..
First off do a leakdown test to make sure your valves and rings are sealing well. This will probably tell you the most amount of information in the shortest amount of time.
Most of your symptoms sould like a boost leak, I know you said you tested to 12 psi and thought the TB gasket was failed... Try pressurizing to 20psi next time and use a spray bottle with soapy water to check all your paper IM gaskets. Also you need to take the TB off, get a new TB gasket and/or RTV it on then retest again. Your **** will never run right if the TB gasket is failed. FYI the TB that came with my motor had a bad shaft seal and would leak anything more than 5psi from under the TPS, might wanna check there too. TPS pops off easily, pressurize then open the throttle and listen for a leak.
Dipstick could have popped out for a few reasons. Basically you're pressurizing your crankcase, I would guess (or rather hope) it's because your PCV valve is old and not holding pressure well anymore. Try plugging the PCV hole in the IM and do your leakdown test again. If the crankcase still pressurizes (you'll hear/feel air through the open PCV line now) then you can bet on a valvestem/ring problem. I still haven't found a good replacement PCV valve, one from VG30DETT "should" work though...
Double check your exh manifold gasket and turbine inlet gaskets to make sure they're holding pressure.
GL
govtworkhorse wrote:So as you all know, my car runs, but runs like crap. Well now I'm stumped. Here is a rundown of the symptoms:
1. Gas in oil but checked compression and it was even and good across the cylinders.
2. Can't build boost. At random levels of boost, depending on how fast I feed it fuel, it will bleed off. (i.e cruising in first and gradually but steadily pressing the pedal, the boost gauge starts to move towards boost but will bleed off back down to vacuum even though I'm still slowly giving it gas)
3. Plugs are black from running way rich
4. A/F ratio is all over the place when cruising under steady throttle. But idles in the "rich" area after car runs for a minute.
5. Capped off the system where the MAF is to pressure test for leaks. Gauge showed I put 12psi in and I heard a little air coming from the throttle body gasket. But hardly any at all.
6. Then my oil dipstick blew out releasing all the pressure.
So I don't know what's going on. Looking to you guys/gals for help. How could my dipstick blow out and have gas in my oil, and still have good/equal compression on all cylinders. Please tell me I'm retarded and there is a simple explanation for all this.
