Rob - that's the answer I was looking for. Thanks - you just saved me $100 and two trips to the junkyard.DAEDALUS wrote:My '93 manual says RTV. Some years ago I asked the same question. An Infiniti tech on this board said the shape of the covers is different--can't swap them. Plus the fastener sizes/bolt pattern are different.
yeah, and also on the 9093 they use bolts for the fastners, and on the 94 they have studs with nuts... So it wont work even in that regard, but as we all know the heads were different....RobertsnewQ wrote:Rob - that's the answer I was looking for. Thanks - you just saved me $100 and two trips to the junkyard.
I may do them tomorrow but if not it will be soon.
That doesn't matter to the valve cover or the gasket. RTV may perform as well as the solid, but it is messy and it takes forever to remove the old stuff.elwesso wrote:yeah, and also on the 9093 they use bolts for the fastners, and on the 94 they have studs with nuts... So it wont work even in that regard,
