silpena »
https://forums.nicoclub.com/silpena-u34788.html
Fri Mar 28, 2008 9:30 pm
I bet your dirty filter lead to dirty maf sensor. This happen to me one time. It ran ruff, idled high, shut off frequently, hard starting in cold or hot, progressively got worse. Start the down with least expensive then work your way up. As for the oil problem problem ur front/rear seals could be it. Go to kreagan and buy some maf sensor cleaner. This is good stuff and last a life time. best 5 dollars ive spent.
