MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Thu Apr 06, 2006 12:36 am
Really slow night. Not much happening. And the few things that have happened have pretty much taken care of themselves.
So I find myself sitting here, playing with my homemade (well...office-made) flamethrower. Actually, flamethrower is a bit of an overstatement...more like mini-torch.
And since I'm really bored, I'm going to tell you ALL about it.
In my pocket, when I came into the office, I had my swiss army knife (a black one...I love it) bic lighter (don't smoke--but I never leave home without a lighter), and one of those little breath spray things (don't even recall why I have it; I've never used it for its intended purpose).
Hmm...lighter...breath spray.
Fire.
After the bottle of spray was about halfway gone, I decided that the flames weren't big enough, and needed enhancement.Luckily for me, we keep several bottles of isopropyl alcohol around the dispatch office for sanitary purposes.
But...the spray container was sealed tight. I tried prying the top off (seperate plastic) but the glue was the plastic-weld variety, so there really wasn't much of a seam.
So I drilled a small hole in the side with my pocketknife. But there was no way I was going to be able to pour the alcohol in that small hole. The solution? A bit of aluminum foil and a shishkebab skewer made a perfectly sized funnel.
So, spray bottle filled with alcohol, I needed to seal the hole. Tape obviously wasn't going to work...We have no glue of any sort...I rolled up a bit of foil and sized it with the skewer, stuffed it into the hole. then I covered it with more foil (for better seal) and then taped around the edges. Didn't work.
Next attempt was to take part of the spray bottle (part of which which I had already removed because it had a stupid arch over the spray button) and heat it with the lighter, then force it into the hole.That didn't work. It stuck to whatever I was forcing it into the hole with (yeah, yeah, innuendoes abound...).
Then I noticed the mechanical pencil sitting next to me on the desk.I removed the eraser, shaved it down with my knife so that it was shaped to match the hole, and viola! A perfect seal.
Except that it didn't stay on it's own.And we don't have glue...tape won't work...
Whiteout!
I put a tiny dab of whiteout on the eraser to hold it in place, let it cure for a moment, then began generously flooding the seam with the liquid. Layer-by-layer, I built up a perfect seal.
Now, I have a spray bottle filled with 100% isoproply alcohol and a lighter.
Also, when I hold the bottle (it's translucent) up to a light, I can see small particles floating about inside. Looks like the alcohol is eating away at either the eraser or the whiteout. Probably not a wise idea to stick the bottle back in my pocket...
The flames still suck compared to those I used to get from another (now nonexistent) brand of breath spray back in highschool. Those ones would yield the most glorious, slowly rolling balls of flame. This new one just looks like a small dragon sneezed or something...
