ca18det240hatch »
https://forums.nicoclub.com/ca18det240hatch-u57383.html
Mon Jul 30, 2007 4:56 pm
well, i think i found out the reason for my low compression and my car running like a$$.
when i took apart the front of the motor, the small timing gear, had moved a bit, bent the key in the keyway, and therefore allowed for about 20 degrees or so of play....so im pretty sure that had a play on my low compression. Anyways, its getting a hone, new rings, and getting re-assembled. did anybody ever have this happen with a key bending? very strange.
other question, can you re-use a cometic metal headgasket?
thx alot all.
