Import_Ant »
https://forums.nicoclub.com/import-ant-u16968.html
Wed Sep 21, 2005 3:51 pm
the car was awesome while it ran. I didnt race too much while I saved for a rebuild because I expected something to go out. When I first installed the kit, I had a couple of boost leaks, timing was retarded by about 4 degrees (I was running a base timing of 11 BTDC for some reason) and I did pretty well against a stage 3 WRX. we did several 30-100 pulls and he had me by about 2-3 cars consistantly. I got the leaks, timing, and other misc probs fixed and ran a Blaster 2 coil and the car pulled a LOT stronger than when I ran him. I never did a compression check because I was afraid of the results and planning on a rebuild. I surmise it was ****ty from the get-go. Ixnay on the dyno also because I was trying to save for complete build up. (60-100$ for a pull around here.)
[The WRX was running UTEC, upgraded turbo, 3" turbo-back exhaust, injectors, short shifter, intake. everything but IC. He ran it to the tune of high 13's at the track before trading it in. gearing is REALLY short on them btw. Trannies hold ~300whp then *boom*]
