AGX settings for the track?
Touring240
just got my kyb agx shocks in yesterday. with eibach sportlines.
they are on 2/4 for daily driving.
whats a good setup for the track?I currently have f/r pilot tower bars and ES sway bar bushings16x7 velox vx8r w/225/50/16 toyo t1s
suggestions? I heard 3/6 is a good way to go
thanks!
zweebach
It's probably going to be somewhat dependent on your driving style and what you like - maybe even the track you're on too.
I know some guys with Z's that have that spring/shock combo will put the fronts on 1 (the lowest setting) to get more compression.
offtheline
How do you like that setup? The sportlines with the kyb agx? Is it comfortable for daily driving?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
i was told the stiffest setting posible will be good for drift and stuff like that. I got the same setup as you but my shocks havent arrived yet :(
Touring240
the setup is great!!! I'm very very happy with it.
I just did driver training (about 6hrs on the track) and did a slalom yesterday at the same track.
I ran 2 on the front and 4 on the rear and it worked out very well. I have no complaints!! my toyo t1s tires helped me out too. next time I'll higher pressures as I was runinng 34 psi front and rear. :(
very neutral car with oversteer at the limit I'm very impressed. (this was my first time taking the 240 to the track)
now its time for power !! I got owned by stealth TT , 97 talon awd tsi, WRX, rx7 TT.
Onizuka
thats some pretty damn good compitition! what are you doing for power?
Touring240
not nearly enough power :(
k&n open element filter w/maf adapterhot shot ceramic header2.5 inch mandrel custom exhaustunorthodox crank pulleyps removed
just installed an R32 fuel pump 10 minutes ago. getting ready to do an SR swap in the near future so I can keep up with those much quicker cars!
Onizuka
was the fuel pump pretty easy to install? direct swap?
Touring240
nearly the same. =)
took me about 2 hrs because I took my time and had problems getting the plate off (lots of rust on the bolts ended up using vice grips)
I used the existing wires from the 240. I just used one zip tie to help secure the pump in place, other wise I didn't need any extra parts.
just a bit of bending of the bracket was needed but otherwise fairly straightforward install.
it does whine louder than stock but that was expected :(
do you use msn or icq? I don't use aim
Onizuka
i only use AIM for right now.
How much did the fuel pump cost? and do you know its flow rating?
Touring240
I paid 80 US for the pump and picked it up from an r32 owner. he was running 400whp when he took it out.
I don't know the flow rating but I don't plan to run more than 300HP :)
I think I'll ask him the flow rate though
KSee777
I'm running 2-5 right now. Oh and uhhh.. does your rear struts make loud "shwish" sound when going over bumps or dips?
Touring240
KSee777 wrote:I'm running 2-5 right now. Oh and uhhh.. does your rear struts make loud "shwish" sound when going over bumps or dips?
yeah they do. I'm not sure what it is.
do you find your rear steps out more with it at 5?
Onizuka
my stock struts make that sound.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i wanna get those struts w/ tein SS coils over em...how would that be? good? also...on enjukuracing.com they have prices for springs by price each...is that per spring? that wouldnt make sense...sorry for my incompetance but i've never looked too hard into suspension before...
KSee777
Touring240 wrote:yeah they do. I'm not sure what it is.
no not really... now if you went to 8, then that's a different story...
Tai Mai Shu
No, that is for a set of 4 springs, coilover's usallay aren't sleeved cept maybe the Ground controls. Most Coilovers dont need shocks, all Tein coilovers do not need shocks. There S types like the ones I have on the other hand are well just that springs.
MainEvent212
i said coils as in springs...didnt mean coil overs...i'm saying, are the SS springs good on KYB AGX struts?
matt0941
Car: Counter-Strike, Cars, Girls (in that order)
Sounds good. I have the SAME setup as you but I am having trouble with the rears (car is on jacks right now) as the KYB strut boots are having trouble, gah! Well good luck with the new setup in the future!
