AGX = prokit
dl240sx
Car: rebuilding cars
was wondering if anyone has AGX and Eibach prokit on thier s14. i am about to put them on but not sure if the koni are better with my springs? also do i need new pillow ball mounts or will the stock ones work.thanksDustin
big jon's 240
Car: uh....football, cars, and um, cars!
Stock mounts will work just fine. I have the same setup.
pancito
Car: CARS!!!
I have AGX all around in my S14 i have them at 3 in the front (from 1 soft to 4 hard) and 5 in the back (from 1 to 8) on STOCK springs. Pro-kits are going to be ordered next week.
BTW are prokits the smallest drop of them all? I just want to lower it 1" or something like that.
Holy Roller
I had the AGX's on my old ride....they were pretty stiff overall, even on the softest setting, which is great for cornering, but the ride can get a little bumpy for daily driving. Keep it a little softer in the front than the rear for optimal handling.
dl240sx
thanks alot for the tips
stickgoat
Yes, Pro-Kits won't drop the car a whole lot...that's why I bought them myself. Didn't want a big drop.
I'm about to install them next weekend, on stock struts for now, but when I have the cash for new ones I'm going with the AGX's myself.
driftaholic
Car: '91 Nissan RM S13
i have tein s.techs on my car. they're a nice drop, but not TOO low.
copy and pastehttp://www.geocities.com/imadriftaholic/1.jpg
i2ice4m3
Car: COUNTERSTRIKE!
hey driftaholic, did you notice a difference in ride quality after the s-techs were installed? I'm assuming you used stock springs previously. Thanks!
driftaholic
my ride is way different now than before, but i changed springs and struts (agx's) at the same time, so i'm not sure how much of the change is due to the springs. check out http://www.speczero.com/tech_s13susp.phpthere are some pics that compare oem springs to s.techs. the s.techs are several inches shorter than the oems, so they must also be quite a bit stiffer if they only lower 1.5" (the car in the article is mine btw)
