AGM Battery
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
bigb56
Car: 2008 Infiniti FX35 RWD
Is there any ECM coding required when changing to AGM on a 2008 FX-35?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
No, and your '08 won't have any "smart charging" to worry about. On later models the smart charge should generally be disabled for AGM, so the alternator output stays above 13.5V. Charging an AGM at voltages lower than that can make you sorry.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
