cwilson93 »
https://forums.nicoclub.com/cwilson93-u123500.html
Fri Aug 14, 2009 9:44 pm
Alright, well my car has been running like s*** ('92 240sx, KA24DE)
My ECU is throwing a code 34 (knock sensor), so i replaced it (sort of lol) after a few hours of messing with it, i decided to just plug it in and ground it just to see if the code would go away then i would go ahead and spend the next few hours bolting it back up...
Well it's STILL throwing a code 34... So my question is, does the knock sensor actually need to be bolted to the block to make the code go away? Because i figured just having it plugged up would be enough just to get the code to go away... or do you think i have a wiring problem between the plug and the ECU?
Any help is greatly appreciated!
