again with my cai on 1.8s
sentra2nr04
Car: 04 sentra
ok i am wiggin out over this damn thing cuz fujita says it only fits on the 06 1.8s and i have the 04 they said that it dont fit cuz there is a different maf that year so wtf and how does it measure air cuz u do away with the maf look at the pic below and tell me cuz i see the plug in plugged in to the intake but iunno wat to do
sentra2nr04
Car: 04 sentra
ok never mind about the part with the maf just pluggin in i see that u have to take the module out of the oem maf but iunno why cant they just make an adapter wtf and i really need help will this fit or not
sentra2nr04
Car: 04 sentra
nametakennow
Car: '06 MINI Cooper S
You'd have to cut out a section of that pipe and use some hose connectors to put your MAF there.
You need: a hacksaw, a file, two silicon hose connectors of whatever diameter you need, 4 screwclamps or T-bolts
What brand is that CAI?
Why not just get one that's designed for an 04?
sentra2nr04
Car: 04 sentra
ok the only one that is designed for my car is the weapon r i think and iunno bout weapon r ,, hotshots discontinued their line of intakes and the fujita one is for the 06
sentra2nr04
Car: 04 sentra
i guess i could buy one of them and saw a part out of it but does nebody know where i can get a maf adapter at
nametakennow
Someone around has a NISMO CAI from a Spec converted to work with a 1.8. I think it was relatively painless. That kind of seems like a simpler option.
sentra2nr04
Car: 04 sentra
ok but what if i cant find one what do u have to do to convert it over??
i found a pic of one but how do i change it over
cut or add?
nametakennow
Here's the thread by another 1.8 owner: zerothread/155738
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
nametakennow wrote:Someone around has a NISMO CAI from a Spec converted to work with a 1.8. I think it was relatively painless. That kind of seems like a simpler option.
Winston I have that 1.8 It's easy and everything fits alls you need is a MAF adapter which you can get at Autozone....etc. Thats all.
sentra2nr04
Car: 04 sentra
ok if everything fits then why dont they sell the same intake for the se-r and 1.8s both
sentra2nr04
Car: 04 sentra
and another question does the intake have the nipple that sticks out for the the valve cover breather hose
NSR_s30
'71 Datsun 240Z
I don't know why they don't sell it, alls I know is the NISMO intake for a Spec V works. Think about it this way all B15's are the same, minus motors and trannies. Everything is in the same place so it's easy to use a intake off another car and just get an adapter for the MAF.
Yes there is a opening on the piping for the valve cover breather. Look at the pics.
sentra2nr04
Car: 04 sentra
ok i think im enuf convince so maybe i will see bout getting it if i can find one for a reasonable price not 250 dollas tho lol the only thing is i looked at the maf sensor autozone sells wont fit i measured the bolt holes then went up there with a template of the holes and was pretty sure it wouldnt fit cuz the one they got has a bigger bolt pattern so does anybody know where i can get a maf or what
NSR_s30
'71 Datsun 240Z
You get what you pay for, I'd go with NISMO if I was you. The adapter I had I had to modify so the holes would work. Just drill them out. DIY FTW! Like I said just use the one and modify it so the bolts work. It's really not that complicated.
sentra2nr04
Car: 04 sentra
i was just wondering if it was the same size hole as the maf for the adapter cuz i bought that one before for my 240sx and even on the back of the package it said it fit yea right couldnt get that thing to work right
NSR_s30
'71 Datsun 240Z
Maybe, as for the adapter I've had it forever and I'm not quite sure where I got it, but like I said the mounting holes had to be drilled out so it'd bolt up with the MAF. Good luck.
sentra2nr04
Car: 04 sentra
hmm does does anybody know what diameter the maf is then cuz i dont feel like taking mine off right now to measure it lol
NSR_s30
'71 Datsun 240Z
lazy
sentra2nr04
Car: 04 sentra
NSR_S13 wrote: lazy
u dam skippy
