auditech10 »
https://forums.nicoclub.com/auditech10-u38958.html
Sat Feb 10, 2007 10:53 pm
Air pressure is air pressure no matter if you have 18inch wheels or 5,000inch wheels. The valve stems that came on your original wheels is what sends the signal/info to the modules at each wheel well and tells the screen what pressure is in each tire. Just make sure you have the tpms valve stems in the wheels and you should be good. Most people know what TPMS is but you have to ask the right questions to get the answers you are looking for.Best Regards,D
