Just found out they have a 19 x 10 +43 I guess that works wonder what that looks like though Don't admire the "flush look" too muchRED_DET wrote:You can't go as aggressive on offsets as the g35. About a 10-15mm difference in offsets when comparing the two. Read the sticky again, I cover offsets for aftermarket wheels for the g37. I know I only listed the oem g37s oem wheel specs, but the aftermarket offsets are for all g37 models. So in your case, no a 22 offset is too aggressive.
I just got the spec on the front wheels I ordered They have a 38 offset would this wheel also benefit from a 5 mm spacer?RED_DET wrote:It will push the wheel out closer to the edge of the fender so they don't look sunken in.
Would you explain exactly how a 5mm spacer would "benefit" the wheel?RED_DET wrote:Absolutely..
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
