Post by justjuiceit4 » https://forums.nicoclub.com/justjuiceit4-u26734.html Sun Mar 13, 2005 8:44 pm
Post by NISTECH » https://forums.nicoclub.com/nistech-u7581.html Mon Mar 14, 2005 4:16 am
The bleed screw is likely your best location as you would want to see the temp just behind the t-stat as head temp is the hottest part of the system. in the block is too low as the coolant temp there is not as high since it is below the combustion area. in the rad hose you would have to much fluctuation between t-stat openings.justjuiceit4 wrote:I did some research and found that the T-fitting is not a good way to go with an aftermarket water temperature gauge. Some places I have thought about placing it is: the bleed screw location, the engine coolant drain plug location(on the block) and inserting an adapter for the upper radiator hose. What are the pros and cons for each of these locations. Thanks.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
