You've done quite a lot on oem valvetrain haveny yah? Amy numbers or type of setup you were using?boost_boy wrote:What's wrong with the stock ones? There up to whatever task that anyone in here including myself can put them through. To repeat what's posted, Ferrea is a quick option that will most definitely be able to assist you.
Dee
400+everyday whp on stock valves, 300+everyday whp on stock valves, multuiple cams, ported and non-ported heads, big injectors, high flow pumps, blah, blah. I just never had an issue with a stock valve burning up, let alone ever breaking a timing belt.davidricardo86 wrote:
Damn that is definately good to hear! If done correctly you can extract lots of power from this little CA! I cant wait till mine starts running again.boost_boy wrote:400+everyday whp on stock valves, 300+everyday whp on stock valves, multuiple cams, ported and non-ported heads, big injectors, high flow pumps, blah, blah. I just never had an issue with a stock valve burning up, let alone ever breaking a timing belt.
Dee
