hey i just noticed my oil feed line to my gt35r is leaking. the line was a braded pressure line and its leaking by the fitting. id like to get some ideas or part numbers on the oil feed line that i can use in place of this one. are you using the stock oil feed position on the rb? i have another line but the fitting is different and id have to run it from the oil pressure sensor location. would that work, then just plug up the stock oil feed port?
thanks
Zak
