Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Dec 28, 2008 5:51 am
The RE4R03A is rated by JATCO at 303 lb/ft max. The early VH could be tuned to ~~ 333 lb/ft and I had one survive 205,000 miles with vigorous exercise weekly.
I wouldn't count on one surviving [built] to much over 400 lb/ft for very long depending on the number of WOT shift.
Remember the TCU> ECU drops ignition advance to zero just before shift and slowly ramps back advance during 0.7>1.0 second after shift. So peak torque on input is in 1st gear at 4,000 rpm...............none of other gears are used to seeing peak since a downshift [4600 rpm] also sees some ignition advance reduction.
When a 75 HP shot of Nitrous was used the transmissions life was cut drastically [unbuilt].
