aftermarket tacho on a CA18......
datsunboy
Car: Datsuns
Hey guys......just wondering what sort of tachos you are running with the CA18?I know there is a wire coming from the ECU for the tacho drive.......but wasnt the silvia a electronic dash?.....and being the fact it has 4 coils.....Im assuming a normal tacho that runs from the distributor wouldn't work?
cheers
themadscientist
tachs operate off the #1 cylinder trigger event so the number of coils doesn't matter. Do you need to know the wire?
WeldingHank
Car: 1989 240sx CA18DET
i always used the yellow/red stripe wire off the dash harness from the ECU.
datsunboy
Car: Datsuns
but if you take the trigger from only 1 coil.....it will only be triggered once for every cycle.as opposed to the single coil method of hooking the tach up to the -ve terminal of the coil......so it's recieving 4 triggers per cycle.......
themadscientist
one wire man, just hook it up, these aren't the droids you are looking for.
float_6969
one wire. That should be it. As Hank said, I think it's the yellow w/ a red stripe.
datsunboy
Car: Datsuns
cheers
