I have searched
Here is the run down. I bought an aftermarket tach off ebay. It has 4 wires coming from it
1)acessory wire (so your tach only comes on in the acc position)
2)12V power (hooked to battery)
3)ground...grounded with ym HU
4)tach signal
Now I have power. I can set the point where the shift light comes on. I have the backlight. But no signal. I spliced the number 4 wire to the number 7 ECU wire. It is yellow/red and according to
http://www.rb20det.com that is the tachometer speed signal. Anyone have any insight as to what I am doing wrong/didnt do???
Another thought.....
Now if I recall correctly the DOHC tach reads half the value or something like that right?? It gives a signal, just not a correct one. I have a DOHC cluster and my tach didnt budge, so could my problem lie somewhere in the swap wiring???
Another thought.....I traced teh yellow/red wire to the engine bay and I "believe" I may hae found the problem. The yellow/red wire is on a plug all by itself. It is cylinderish in shape (can't thik of a better word, but ti is the ONLY one of its kind in the bay. If someone with a swap ca look at that plug and tell me if your has some sortr of cap on it or if it is plugged into something, that would be great......
