drftnrps13 wrote:so i dont need the tach adapter anyways? but i thought if u had ind. coils u need the tach adapter! ok ill try that then!
nooo what the piss is a tach adapter.. i dont have one my tach works fine whenever my engine starts
so if i dont have one then u dont need one. use ecu pin 7 to rev signal hook up to the new tach slice the wire in
or look around your harness and look for something like this it'll have a yellow/red wire going to, pull the black cap off and run the new tach wire this. it's fine and i'll work thats on my harness and i ended up finding out and follow it to ecu pin 7
