95240SE »
https://forums.nicoclub.com/95240se-u6030.html
Fri Sep 05, 2003 8:36 am
if by leaking you mean that the water is collecting inside the car then that means the drainage tube(s) are getting blocked somehow and the water isnt passing throw which leads it to collect inside the car. As for the sunroof not working its most likely the motor. I also have the same 2 problems that you have.
I dought the weatherstriping has anything to do with it because from what a mechanic told me is that there is a tube that goes from somewhere in the sunroof and goes down the rear pillar and then the water just exists onto the ground. When that tube gets blocked the water just overflows and get inside the car.
hope this helped you out
