airman86 »
https://forums.nicoclub.com/airman86-u126597.html
Thu Mar 12, 2009 5:18 pm
Hey all, i'm starting to do a little bit of research on what i'm going to need when building my future 240sx. I want a '91-'94 S13, but I plan on fully rebuilding it. Because i'm going to be building it anyways, I'm looking for one that needs help (like a blown head gasket, or something along the lines that can be found for cheap). However, that's against the point.
So, block will be bored 20 or 30 over, new rods, pistons, crank turned/resurfaced, yada yada. As far as head work though, I plan on going with a more agressive set of 264 or 272 cams. I will be turboing this setup eventually, but i plan on doing things one step at a time, as i'm not going to rush the project. More questions on that later.
ANYWAYS, my question is this. I will be having the head machined/cleaned up/etc, but since I'm throwing some nice big cams in the car, is it necessary to spend $300-$400 on a set of BC springs and retainers, or some other name-brand? It will, of course, be getting new seals and have the valves cleaned up, unless I am recommended to spend the money on a set of aftermarket valves as well, or if they need replacing anyways. If they just need replacing, would an OEM set of valves for less than a third of the cost of BCs be okay?
For example, I had my head from an old eclipse of mine machined and fixed up and it went from this:
to this:
Those are the original, stock valves, all cleaned up. The machine shop I deal with does VERY good work.
With a built bottom end, like I am planning on, I am looking for ~400hp which I think that is reasonable if I take my time and do it right. With horsepower levels that high, as far as head work goes, i know i will at LEAST be doing cams/new seals/cleaning valves/resurfacing the head. What do you guys think about spending over $600 for a set of valves (assuming the ones in it aren't worn or need replacing), springs, and retainers? Necessary?
I have set my goal for 400whp, which i'm pretty sure is reasonable. But with a built bottom end, forged pistons, built (although not sure how "much") head, and something like a GT30R, and i'm pretty sure the gt30r can do ~25psi, assuming correct fuel delivery, suspension, all electronics goodies, etc, would this setup hold that and not fall apart?
Also on a side note, besides the necessity of a new clutch that can hold this amount of power, will the transmission need to be beefed up? Most of the projects i have dealt with are no more than 300hp, and I didn't have to modify the transmission at all.
Modified by airman86 at 5:58 AM 3/13/2009
