Aftermarket Spring Rates
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
I'll be looking into lowering springs for my G35 before too long, I don't need any kind of major drop, just a bit lower than stock, but I want to keep the spring rates as close to stock as possible. So far I haven't been able to find much info on the rates for most of the popular aftermarket springs, or even the stock ones for that matter. The car is an 06 G35 6MT with the sport package. Can anyone point me in the right direction?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Notes: STech Springs
Manufacturer: TEIN
Ride Height (R): -0.9in (-23mm)
Spring Rate (F): 358lbs/in (6.4kgf/mm)
Ride Height (F): -1.2in (-30mm)
Spring Rate (R): 274lbs/in (4.9kgf/mm)
Notes: HTech Springs
Manufacturer: TEIN
Ride Height (F): -1.4in (-34.5mm)
Spring Rate (R): 263lbs/in (4.7kgf/mm)
Spring Rate (F): 324lbs/in (5.8kgf/mm)
Ride Height (R): -0.7in (-17mm)
Notes: Pro Kit Springs
Manufacturer: Eibach
Front Lowering: 1.1in
Rear Lowering: 1.0in
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2008 (revised suspension)
Front:314 Rear:427
Whenever you are ready to pull the trigger, let me know and I will take care of you.
SX APPEAL
95 Maxima SE 5MT
Good stuff, thanks! Looks like the Eibachs are the closest to what I'm looking for. Might be interested to see how the Pro Kit's compare to the Sportline's as far as the rates go, seems kind of backwards that the Sportline springs are the more aggressive of the two. Would you happen to have any info on those as well?
RED_DET
Vendor
2011 Infiniti G37x
Notes: Sportline Springs
Front Lowering: 1.6in
Rear Lowering: 1.4in
F: 239/400 R: 257/435
SX APPEAL
95 Maxima SE 5MT
Awesome thanks!
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
