Post by Tomsoxfan » https://forums.nicoclub.com/tomsoxfan-u71282.html Sat May 31, 2008 11:07 am
Post by r3v_v3ng3 » https://forums.nicoclub.com/r3v-v3ng3-u58043.html Sun Jun 08, 2008 10:01 pm
you can probably run a relay. that way it doesn't draw much from the stock voltage/ampsTomsoxfan wrote:How do I go about wiring the 3rd brake light on a aftermarket spoiler that doesnt have a plug on end of wires to plug into the harness the inside window 3rd brake light uses . I have heard stories if you splice the wires and dont use the plug then every time you step on the brake a BULB OUT error shows...Is this true ?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
