elwesso wrote:I know PMQ has said that he had good results using aftermarket speakers with bose.. Regardless of if you think he's an idiot, I respect his opinion in audio equipment...
Thanks, Insult + Respect = OK
ANyway, I suggest that you just replace the REAR speakers with a descent set of 6x9s. I'm talking about you getting a pair that you'll keep using even AFTER you upgrade the rest of the system.
I was talking to Keith(Rex) about the power of the Bose amps, and we came to the conclusion that it's around 50w per amp at 1ohm. So, with most aftermarket speakers you'd get a 4Ohm load which would give you ~12.5w~20w. Even though that is kind of low, most 6x9 triaxial/coaxials are pertty efficient and will play plenty loud.
About the Eq being disabled when using stock speakers... That's not true. Using the Equalizer alters the signal being sent the amplifiers. The speakers don't have anything to do with it. So turning up the bass/treble will increase the bass/treble
ANyway, I say install a good pair of 6x9s. If you're not satisfied, just return them
