AFTERMARKET SPEAKERS INTO MY 91 240sx LE W/stock in-door amps. HELP
Post all your Nissan electronics, car audio and stereo questions here!
johndabrit
Car: 91 240sx LE modified air box, hi-flo cat, 300z fuel filter, blown speakers
I have searched and searched and cannot find a REAL answer to this question. But first here is the setup.
91 240sx LE hatchbackAlpine head unit.2 10" JL subs.1 alpine amp for subs.
trying to install aftermarket speakers in the doorsI am trying to replace the stock front speakers with some pioneers of the same size. They fit in perfectly but in my car i have the in-door amps. The amps with my head unit and i don't want to bypass them. The old speakers just sound like hell. Here is my problem:
The plug that goes to the speakers has five wires total.The new speakers have standard + and - terminals.HOW DO I WIRE UP MY NEW SPEAKERS WITHOUT BYPASSING THE STOCK AMP?
fyi: i did search the forum for this and the only i can find is info on putting a different size speaker in the door. No mention of the actual wiring other than this quote.
240Knightrider wrote:ok, i installed new speakers in my front doors. I believe the amp has been disconnected because I have five spliced wires hanging out.. I know two wires connect the speaker and they work...but my antenna doesnt work and I cant figure this out. there are three wires left. Does anyone know how to wire it to make my antenna work again. When I connected two of the other wires the antenna worked but it look right to me. Thanks in advance
It seems like two of the wires are in fact for the speakers. Two for the antenna. What is the fifth one for? and how can i tell the difference between them?Thanks in advance to anybody who has gone through this BS.
John
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Mine only had the two wires, the positive and the negative wires on the stock speakers.
phuphyter
Car: 2002 Infinity G20
Personally I'd run new wires, but if you must use the factory amp, try this: zerothread?id=52883
scroll down to the bottom two posts. they should have the info you need
