Hey Guys.Im new on here from SON240SX.ca forums
I am planning to purchase a set of sway bars for my S13 240SX and I have researched the following.
S13. Tanabe - Front bar 30.4mm, 22mm in the rear. Tubular chromoly construction. Stock type endlinksS14. Tanabe - Front bar 30.4mm, 27.5mm in the rear. Tubular chromoly construction. Stock type endlinks
And I can see that the rear sway bar for S13 from tanabe is alot smaller than for the S14. Could this be because of the rear weight difference between the S13 and S14 ?
I have tried putting my stock sway bar from my S13 onto the S14 and it seems to fit and work no problem. I am running a HKS Jasma 4" catback on my S13.
If anyone knows whether the sway bar would fit or has tried putting aftermarket rear sway bar from S14 onto an S13 and it worked, please let me know ASAP. Thank you.
