Aftermarket Radio problem???
ZELsJ30t
Car: Infiniti J30t 1993
I bought a 93 j30t the previous owner clipped the harness in the back of the radio and now aftermarket radio wont power up any suggestions?
htbyrico
Car: 1996 Inifiniti Q45/ Nissan President
check all fuses.. should be a 15 amp.. with a test light or volt meter.. after that with volt meter or test light.. check for power in all the wires that are cut.. you should have 2 that has power with key on engine off.. turn key off then check again should be one with 12 volt power.. mark that one because that's going to be you red wire on your aftermarket radio.. your yellow is the other one that comes on with the key on !! hope this helps.. as far for speakers ill let you know as soon as you let me know how you did in finding power.. :bigthumb:
ZELsJ30t
Thanks for the help i did figure out the radio power after that it was a walk in the park speaker wise thanks for the help
htbyrico
glad to help..
