teddy »
https://forums.nicoclub.com/teddy-u22985.html
Tue Jun 06, 2006 11:48 am
Koyo - $300PWR - $450Koyo Copper - $130-150ishFluidyne - $480
These are the major brands and prices that I can think of. If your KA(assuming you have a KA) is stock or close to stock and the stock radiator is still working, I see no cause for you to replace it. The radiator in combo with the stock clutch fan do a great job out of the box.
Many people upgrade because of the higher temps caused by the turbo, or because their stock radiator is on its last leg and isn't functioning properly. The upgraded radiators work very well and are always a good investment. The last thing anyone wants is to overheat their engine. Koyo is typically the most popular just because of the price and it works just as good as the others.
I know most of the rads have mounting holes for the stock shroud, so I see no reason why a reputable brand would have problems using the stock fan, unless the company mentions that you can't use it.
If you're looking for a cheap rad/fan combo, the Koyo copper and altima fans are the way to go. The koyo copper was actually tested to cool better than all the other brands out there, before Koyo redesigned their aluminum radiator though. Altima fans can be had for cheap and flow pretty well.
Just mess with the search function. There are countless threads on radiator/fan combos.
