MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Fri Jul 09, 2010 12:59 am
You want to get the right cap for your car. The rad cap is a failsafe, designed to leak so other components don't. If you get too strong a cap, you might end up with worse problems down the road.
That said, I've had problems with cheap radiator caps that were supposedly the right weight for my car in the past. Stepping up to a pricier one (which happened to have a safety relief valve built in) solved my problems.
Spring weight should be stamped or printed on the stock cap. Make sure to match it with any replacements. If you go too light, you could end up leaking when there's nothing wrong.
