Has anyone installed an aftermarket liftgate? I bought a 2015 Rogue yesterday that didn't come w/ it, & am just checking my options for aftermarket things that I could get over time.
Thanks so much
I knew it did not have it but it is not my main vehicle, and other factors outweighed that. Additionally, I knew retrofit kits existed. So thank you for your help.
I actually figured out the power source issue. My issue now is I can't seem to figure out the wiring diagram to determine which wire in pillar b is the unlock signal. I've got 5 striped wires and 1 blue wire but the diagram doesn't seem to say much about striped wires. I guess I was trying to figure out which one it was without a multimeter.ras_oscar wrote: ↑Sun Jun 17, 2018 6:17 amI'm not quite sure what you're asking us. You said the fuse supplied doesn't fit, so I assume you have found the fuse box.
By definition, a fuse panel has to be accessible to service and repair blown fuses, so no dash disassembly should be required.
Are they asking you to power the circuit from an existing circuit serving the lift gate? Do they say which one? (At the lift gate end, did you run a new wire to the fuse panel or reuse a wire that was already in place?) What did it plug in to before? Is this kit a generic, one model for all vehicles or tailored specifically for your year of Rogue?
Hey did you ever figured out which wire is the unlock wire? And if so did it work?paris013 wrote: ↑Sun Jun 17, 2018 2:33 pmI actually figured out the power source issue. My issue now is I can't seem to figure out the wiring diagram to determine which wire in pillar b is the unlock signal. I've got 5 striped wires and 1 blue wire but the diagram doesn't seem to say much about striped wires. I guess I was trying to figure out which one it was without a multimeter.ras_oscar wrote: ↑Sun Jun 17, 2018 6:17 amI'm not quite sure what you're asking us. You said the fuse supplied doesn't fit, so I assume you have found the fuse box.
