MadSideways »
https://forums.nicoclub.com/madsideways-u3356.html
Fri Jan 16, 2004 11:13 am
If you have the s13 engine in your car, you need to get the s13 greddy front mount aswell, and not the s14 front mount. I say this because I have an s14 with a s13 redtop, and I have the s13 front mount. Only because I heard that it was necessary here on the forums. Also, even with the s13 FMIC, it will not allow for the windshield wiper reservoir to stay.
Also, the larger KA a/c line will not reach the a/c, you'll need a custom line made that is longer, and bends around like the sr line. And the KA throttle body will not allow you to get CC w/the swap, you need a custom throttle mechanism to be made. And the EGR sensor on the Turbo Outlet pipe will not clear the steering rack. I had to move it lower on the pipe.
Everything else is just about the same.
