Great, I figured that even if it was eletrical, the voltage sent could be different. That there would be a sender that defi provided which translated the pressure to voltage and then to the meter.Slo_240sx wrote:There are 2 types of gauges. Mechanical and Electrical. Which do you have? The parts you bought are for a mechanical gauge. You mentioned earlier that you can hook up wires and that would be for an electrical. Seeing as how they are defi gauges more than likely you have an electrical gauge. There are 2 wire off of the pressure sensor. Yellow/white is for the cluster (light) while the blue is for the gauge. Unless you used the skyline gauge cluster you have no cluster oil gauge so run your signal wire from the blue wire to the gauge.-Alex
