rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Wed Jul 07, 2004 5:12 pm
Back StoryOk, I have been running numbers (as in bank account) and doing some soul searching. S-Tunes are going to stay, but I am adding p/b upper mounts. That being said, I want to run streetable suspension parts that will also be competent for the track. Spec on the S-Tunes are as follows:
Springs: F: 5.2kg/mmR: 3.73kg/mmDampner:F: 353lbfR: 323lbfDrop:F: 25mmR: 15mm
Ok, more info:According to the literature that I received with the setup, the development vehicle had Nismo Suspension Link Set (which is IIRC just silver stock cast pieces w/ Nismo bushings in them).
Even more crap (aka: What Is Also On The Car Now):-HICAS rear sway (21mm)-p/b traction control rods (ProjectSilvia)
Question:Ok. So I am looking at modifying my suspension all the way. As in do everything that I can. I am not too sure what rear multilink setup to get. Looking at SPLs Pro kit makes me hard, so the obvious engineering/adjustment/value is an easy choice. BUT, Nismo reccomends their stuff. The alignment specs don't look very aggressive (I can provide the Nismo alignment specs if anyone wants them for ****s and giggles...S13 K's and S14 270R specs), so would the p/b pieces be worth it? Other than the spherical Heim joint bushing, I am really getting very little out of the SPL stuff. Or how about this: What rubber and what spherical bushings are the best for me to replace? Which arms/links are the best ones to get adjustible units to replace the stock worn to hell ones? Sorry for all the dry info, but I really want a dialed in suspension. Limits may not be too terribly high, but at least at the limit, the car will be predictible and fun.
