I used a stock KA trans mount flipped around- no mods necessary except a couple 10cent "spacers".
The custom 1-piece driveshaft i had made at
http://www.shafts.com which is local to me....1 day-service About $350- worth every penny.
The parts they used:part number________description________________quantity3103-30_________Nissan 4x4 Hardbody Slip Yoke______13102-21_________1310/Nissan Conversion Flange______1N2-28-437________1310 3 x .083 Tube Yokes_________21-0153___________1310 Series Joint________________2N24-30-42-108_______3 x .083 Tubing______________3.5
The metal on the crossmember where the new holes are, are double-thick steel, no weakness by not welding up the old holes.
number 1 is the engine to mount bracket (never modified).number 2 is the engine mount....i made the cut and removed an inch where the white line is.
Modified by Boardman at 2:04 PM 9/9/2004
