Aftermarket LSD for a J30 diff
dustyk
Are the internals of a J30 viscous the same as a S13 240sx viscous? I have a KAAZ LSD for a S13 240sx with viscous rear diff and I wanted to know if it will fit into the J30.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
It will fit just fine...both are R200V differentials...the J30 case is longer, but that only affects pinion length. The center section (what the KAAZ is) is the same for all R200s.
For example, I'm using a J30 viscous coupling in my S14 open diff case...
- Brian
