Aftermarket Interchangability
W1ccaboy
Car: 1989 240SX Coupe
I'm going to be getting my re-enlistment bonus soon, and was looking into getting some stuff for my 89 coupe. It only has the single cam engine, which I'm okay with. Back when I was a honda guy I made an 11 second D16. I'm mostly going to do suspension stuff to the coupe, but I would like to do some stuff to the engine, I haven't been able to find anything for the KA24E only the DE or the SR20. Like I said earlier I used to be a honda guy and ALOT of hondas parts are interchangable. My question is, are the basic intake and exhaust parts the same on the DE? I know people are going to suggest doing an engine swap but that is far away from my ability, due to me needing the car on a daily basis.
So summing it all up I was wondering if anyone knows what is interchangable on the E and DE.
neverlift
an air intake(kinda),cat~back,for 89~94 all suspension(depending on hicas or not),maf adapter...
alot changed in 91' the block got different piston and oil squirters,the head was completely redesigned,and uses dual cams and 16 bit ecu,the injectors are side feed not top feed like on the E,I believe the intake port is changed,I know the exhaust ports and flange bolts are changed... I will leave some stuff for others to chime in but alot is changed Welcome to nico btw
W1ccaboy
Thanks, I was hoping you weren't going to say that. Looks like I'm going to have to search alot more for aftermarket stuff.
neverlift
not trying to be a d!ck ,but if you had been more specific as to parts you may get more response. I still dont know what parts you are looking for, try the sponsors to the right of the page.... tell us what your looking for.
W1ccaboy
Basicly what I'm looking for is Intake manifold and header. But after looking at the Turbo install on the install page I'm thinking I might try a small turbo setup. So I might be needing to upgrade the pistons. But for now all I would like is Intake manifold, intake, headers and exhaust.
