dangeris »
https://forums.nicoclub.com/dangeris-u76570.html
Sat Mar 01, 2008 3:20 pm
Well I personally have the Injen short ram on my 3.5. It comes with a deflector which when installed is facing downwards (below the filter). Aside from that, the transmission is right below it as well as the protective shroud that is clipped on to the front bumper and to the frame below the engine...but that is on the coupe. Not sure of the sedan but I'm assuming that it is a similar setup.
I just went thru the car wash today and opted for the under carriage wash. After going thru it and drying the car, when I opened the hood, everything was dry! So I would suspect its safe to say that you should be good.
