blackteam02 wrote:after researching all of the intakes out for the 3.5 a/c i found that the stock mass air flow sensor is still used after install.
i found that JETCHIP.com has the "POWR-FLO MASS AIR SENSOR" Part#69138claiming that the Stock Air sensor is very restrictive, especially for aftermarket air intakes. after install the Air flow is increased upwards of 45%, im sure thats a general number they use.
Does anyone know anything about these aftermarket air sensors? would this give aftermarket intakes EVEN MORE sound and/or horses??
We've tested the JET MAF and it is basically the stock part. It is the exact same size and shape and does exactly nothing to change the way air flows in the MAF tube. Biggest BS claim in the industry.
We offer a replacment MAF but ONLY for one reason. In forced induction applications the stock MAF only reads approx 400whp worth of air. The HPX MAF we had built to use with our software in FI applications is rated at appox 1000whp worth of flow metering. It does absolutely nothing for performance and cannot be used without our tuning software.
The stock MAF tube and stock MAF haven't shown a real pressure drop till you hit 700+hp so I wouldn't worry too much about it as a performance modification.
