Aftermarket Intake Manifold?
7HE_DON
I've looked around a lot. Aftermarket Intake Manifold... hmmm....
I've been told that honing and boring out the intake manifold helps air passage and smoother turbulance within the chambers when the valve suddenly closes (maintains air velocity so when the valve opens it already has mommentum to charge in; inherently helps 'static compression' on N/A specs).
Is there such thing with the 240sx?I've seen MANY aftermarket intake manifolds for honda's. Are we left in the dark about something or inadvertantly evading a marketing gimmick?
BuudWeizErr
GReddy.
nismo2887
i think he means for the ka
lessthanjakejohn
Talk to Lime Creek Motorsports, Chris (Aries) was thinkin about makin a custom manifold. He may be able to help you.
7HE_DON
their website doesnt seem to have working links nor contact info.do they have a catolog i can order out for?
GEO
Car: 95 240sx KA-T
wh00t
7HE_DON
Vengeance wrote:wh00t
although that gave me a hard-on that didnt help the manifold question lol:eek:
bruinbear714
uh oh, he's backkkkkkkkkkk!
7HE_DON
bruinbear714 wrote:uh oh, he's backkkkkkkkkkk!
:rolleyes ... dude... i havnt been workin on my car for a long time cuz i find school more important... but if you wanna start a flame like good ol' times you'll just prove myself correct in the first place... i dont start flames and i dont go looking for them...
so either help me out by answering the question without the tangents about my spelling, what i say, what i mean, what you thought i meant etc. we'll get along just fine
7HE_DON
ok it took almost a week to find this out.. just searched online a ton.. then finally asked some local friends and they say the only aftermarket intake manifold made was done by Greddy and has been discontinued for a LONG time which is why you dont find it on any retail stores...
book-ends
Car: ???? Nissan 240SX coupe S13
You could always take it to the next level and have the ECU re-tuned for no MAF sensor and then go custom velocity stack setup with four individual throttle bodies............ If you never did another mod to your car, you could still call yourself a true bad *** and get away with it.
7HE_DON
sounds complicatedare you meaning to say have a setup thats something like the open header intake manifolds they have for the SR20's?i've seen them in a lot of japanese sports car magazinesthey look like 4 trumpet bells that suck in air to the throttle bodies
on the subject the new M3 throttle rack is tite when it revs
APEXi240
Car: 08 Nissan Versa S hatch
7HE_DON wrote:open header intake manifolds
What the hell is that? Are you refferring to individual throttle bodies? Because if so that is what they are called.
EnzoRWD
Car: 1997 Volvo 850 T5
oohh that would be bad azz. ive seen 240z motors with ind throttle bodies and trumpets. would this be anywhere near worth the effort on a dohc KA?-Enzo
Guam_Guy
I know its been a while since this post started but I am in the process of fabricating a short runner intake maifold. I am in the building process right now. Will keep you guys posted
Guam_Guy
I can also get individual throttle bodies for the KA24DE, but it is very, very expensive. Great setup if you wanna go NA. The kit I can get includes manifold, throttle bodies, linkage, injectors, fuel rail...pretty much everything besides the ECU. You have to use an aftermarket stand-alone though. Talking big bucks here but hey if $$$$.$$ aren't a problem go for it!
book-ends
Hello,
I would be very interested to see what you have to offer, would you mind e-mailing me with your website info, or contact information?
EnzoRWD
me too, wont cost anything to take a look.-Enzommmm ITBs
Guam_Guy
well guys I am dealing directly with TWM Induction, You can check out their website at http://www.twminduction.com/
EnzoRWD
yes but from ive researched, the SOHC KA has a motorsports manifolds that can be fitted with ITBs from TWM, but no such manifold exists for the DOHC motor. which is a problem. does TWM offer something, or are they planning on something for the ka24DE? or do i have to pick up a spare manifold and start welding?-Enzo
Guam_Guy
He can fab the manifold for you. I am fabricating one right now. If you have welding background i reccomend you do the same.
EnzoRWD
whats the cost on the manifold? i dont have a lot of experience, and im not sure i would be able to make this thing...what would i need anyway? im thinking about cutting the long runners, and somehow adding a fuel rail and ITBs w/ horns. then the thing would bolt on to the engine fine, but ?? how do i go about this? im concerned about the ports and such being way screwy and negating any gains...-Enzoif the cost was right ill just buy one. that way the quality will be better anyways.
Guam_Guy
total cost for the whole ITB system is $2600.00, that includes, manifold, throttle bodies, injectors, fuel rail and all hardware. The actual kit will take some time create due to the manifold fabrication. I believe he said when he gets enough people interested in it, it should be something like 160 days before the finished product can be delivered.
