Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Mon Jun 14, 2004 9:45 am
I used it for three hours--i already said that. Telling someone to use the search function says that you assume that they havent already. Like I said--it discourages people from asking questions. I searched for this project for a while, and still ma-using terms as ca 95 lb injectors", "ca project:(very broad--should have pulled up more), etc--still nothing. The search funstion sucks--lol.
The comparison is what the injectors can hold out , not the motor they are used on. The motors are different, but not so different. Theres nothing that the ca uses that the sr doesnt use. MAf, coil packs, DOHC, revs above 7200 safely, etc. So the fact that they are only seperated by .2 liters of displacement doesnt mean tehy share "any charactoristics" Except for the torque numbers and the power bancd, hp is hp. The ca wont be able to take advantage of the 95 lb injectors, and when revving from a stop, they will most likely cause the car to bog down. Those 850s regardless of motor will support more fuel than 550 to the wheels.If this person is using 95 lb injectors, then they would support of 800 or so to the wheels. Overkill CAN happen, and is not a good thing, And if its too big, then at idle, you could run the risk of washing the cylinder walls at idle unless you are running a full standalone, which im sure you are. Washing the walls--you can kiss his bottom end good bye. Bearings, rings, etc--theyll all take a crap. like i said--im sure youre using a standalone though.Heres the problem though. Even with a standalone, you cant enter a negative value with the pulse duty, wither at idel or whenever. So if the injector is spraying too much at idle, you wont be able to adjustit enough. eve going down by 50 percent, it will still be spraying the duty cycle of a idling 440cc injector. 440's dont even spray full volume at idle, they are leaned out to prevent too much fuel from entering the combustion chamber.Im sure you have figured a way around this, i wish you all the good luck.
-Josh
