I was just messing with you.
Clear Corners is certainly one of those unlimited budget places I like to stop by now and again but can't see buying more than a piece or two at a time thanks to the prices. Mine need some attention and even though I'd love to have a set of Clear Corners I can't warrant spending close to $2000 on them (and I'd love to have the ones from the '07 & '08s but I'd get hit with a core charge since I wouldn't be sending a set in
) Maybe I'll check into the Meguiar's headlight restoration kit.
You could always check salvage yards and see if there's a wrecked Z that you pick from. The only problem is that most of the Z's that I've seen that end up wrecked have severe front end damage. You might be able find one that was rear ended and totalled out or get lucky and fined a couple that just have one front corner ruined so you can get the opposite side headlight.
