e_c »
https://forums.nicoclub.com/e-c-u14217.html
Sun Jul 10, 2005 7:35 am
try a few different places for the power, ie: the dimmer as you mentioned earlier, the power for your cd deck, or find the power wore behind your gauges that gets power when you thrun on your lights, i would try the first two first, as they are the easiest, but would probably try to do the third option, as i think that is the correct place to do it... as for ground, either find a ground behind the dash, or make a new one and ground it to a screw going into metal, like the fire wall.... i dont know about cleaning it though... sorry.. hope this helps
