The first one is a Water Temp gauge. It has the probe already attached to the gauge and there is also a captured brass nut behind the probe head to tighten up to the engine. I'm sure these gauges were intended for a v8 or v6, but my tiny little 2.4 4 banger doesn't look like this thing will fit. I read in the haynes manual that the truck already has a digital (varying ground) sensor near the front corner of the head which would be near the water neck. If I disconnect the electrical sensor, will that cause a problem with the ecu or should I run this aftermarket gauge in tandem with that sensor?
The second gauge is the oil pressure gauge. The haynes manual was very vague about where the OP sending unit is, but it showed it near the rear of the block on the left side. I don't have the sending unit tube/fittings for this gauge. Are all aftermarket sending unit kits for OP the same? Again, where should I put this sending unit piece in at? Should I run this gauge in tandem with the factory sending unit, or is it ok to remove the OE one?
The last gauge is the ammeter. It goes between the alternator and the hot post for the battery, right? Any or all advice you can give me would be greatly appreciated.
