Aftermarket Gauge Installation S13
ldaigle0
Car: 1993 240sx
I need to find a good 12 volt power source to install Auto Meter gauges as well as a power source for the lights without causing catastrophic electrical system failure like in my last car.
onosqv
Car: '92 240sx Vert
You can tap into cig lighter, radio 12v constant or acc on, or ignition acc, or parking light/headlight wire.
Just use a multimeter to find the wire - i.e. if you are gonna do acc, put a multimeter to each of the wires and see which one gets 12v when you turn the key from off -> acc.
Next, unplug the negative of your battery (so you won't cause catastrophic problems).
Then wire up everything and put an in-line fuse for the power wire so u don't blow anything up (if you are paranoid).
Then you're set to go.
